APIC and Switch Storage Faults
SIMMN
I have a small fabric and I am trying to schedule to upgrade it to ver 2.1(3j) from 1.3(2k). However there are critical faults showing equipment is full or high usage...
For APIC Controllers:
More specifically the useage of /firmware and /rfs2 on the three APIC is showing 100%.
I did some research but found nothing really related per-say...Wonder anyone could help share some lights. Here below are some relevant screenshots. Even with the Recommended Action within each Fault, I am not sure how to replace the storage unit...I know the APIC controllers do not have that manage firmwares saved.
For Switches:
They all (two spine and two leafs) show the same fault regarding /mnt/pss. Screenshot is below.
B.kablawi90
Actually it's a bug in the system. The bug ID CSCvd36006 occurs when running a firmware version between 1.3(2m) and 2.1(2e)
This error requires to open a case with Cisco TAC to enable the internal access to the file system.
Below links for includes the bug description.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd36006/?rfs=iqvred
If my response helped you, don't forget to rate it as helpful :)
Bassel Kablawi.
I did see that bug. Not sure I agree that it is the cause of the issue I have...assuming it is for the APIC even when running 1.3(2k), what about the switches?
Both switches and controller is referring to storage issue, and need to free up space from a disk.
If you have a valid support contact save the time and contact TAC they can access the internal file system and make the required changes.
