Deployment problem with ACI simulator on vCenter.
krzysztof sk
 We deployed ova file according to manual and can't reach oob interfaces from outside no matter how topology was deployed. Maybe there are something misconfiguration from scratch or we missed some point through ova deployment. Is there any manual with installation on vCenter.
Krzysztof Sk.
RedNectar
Hi @krzysztof sk ,
I know you said you "deployed ova file according to manual" - but can you double check that you DID NOT CHANGE ANY DEFAULT VALUES when you first booted up the sim - with the exception of the OOB IP address/mask/gateway
Also, check vCentre - are the interfaces of the Sim
  1. Connected, and
  2. Connected to the correct portgroup?
RedNectar aka Chris Welsh.
RedNectar
Hi @krzysztof sk ,
  1. Connected, and
krzysztof sk
Thanks, we've probably missed portgroup confgiuration. Is it special configuration of mensioned portgroup or made by default?
BR.
Krzysztof Skowron
dangome2
@krzysztof sk how did you fix the issue?
