Destination vPC VTEP Address for ACI
dhr.tech1
Hi All,
We're using ACI in our environment and ran below command. I am not able to figure out on which leaf the tunnel destination "10.9.152.77" resides. I think the tunnel destination is the VTEP assigned to a vPC. How can we search it centrally and by avoid logging into each leaf.
cat-lef-1# show int tunnel91
Tunnel91 is up
MTU 9000 bytes, BW 0 Kbit
Transport protocol is in VRF "overlay-1"
Tunnel protocol/transport is ivxlan
Tunnel source 10.9.32.67/32 (lo0)
Tunnel destination 10.9.152.77
Output 2:
cat-lef-1# cat /mit/sys/tunnel-[tunnel1]/summary
# Tunnel Interface
aclTcamStQual :
adminSt : up
cfgdMtu : 9000
dest : 10.9.152.77
dn : sys/tunnel-[tunnel1]
idRequestorDn : sys/isis/inst-default/dom-overlay-1/lvl-l1/db-dtep/dtep-[10.9.152.77]
iod : 66
monPolDn : uni/fabric/monfab-default
operSt : up
rn : tunnel-[tunnel1]
src : 10.9.32.67/32
status :
tLayer : l3
tType : ivxlan
tmCfgFailedBmp :
tmCfgFailedTs : 00:00:00:00.000
tmCfgState : 0
type : physical
underlayVrfName :
v6Src : 0.0.0.0
vrfName : overlay-1
RedNectar
Hi @dhr.tech1 ,
You are trying to fix a broken light bulb by pulling the main switchboard apart!
In other words, I think you are looking in the wrong place for whatever your problem is.
But back to your question. If the VTEP 10.9.152.77 is indeed the vPC VTEP, then it will reside on each leaf.  You can determine the IP address of the VPC by navigating to Fabric > Access Policies > Policies > Switch > Virtual Port Channel Default
But the comment you make ...
... worries me - because you will NEVER want to use the VTEP address to log into a leaf unless you are already logged into the APIC, in which case you should use something like ssh leaf1201 or similar based on the name you gave the leaf. The APIC's host file will find the appropriate address.
RedNectar aka Chris Welsh.
RedNectar
Hi @dhr.tech1 ,
dhr.tech1
Thanks Chris, although I am bit new to ACI (closely worked on NSX VXLAN) but I don't think the vPC VTEP exists on all the leaf, it does on for NSX as we use Asymmetric Routing and Bridging but for ACI we use symmetric i.e. MAC VRFs are not required on the leaf where it is not required.
When I run "show system internal epm vpc" from the leaf I got the tunnel details only for the vPC hosted on the leaf itself.
Hi @dhr.tech1 ,
Correct. That is EXACTLY how ACI works. A leaf will never need to know the VTEP of a VPC until there is a flow that has a destination on the VPC, in which the leaf will receive an encapsulated frame from the device on the VPC, and from that frame the remote leaf will learn the VTEP address of the VPC. And even then, all you'll see in the endpoint table is the tunnel id that points to that VTEP.
If you want to know which tunnel ID a leaf uses for a remote VPC, then use this command:
show interface | grep Tunnel | grep -B3 <DTEP of VPC>
Leaf101# show interface | grep Tunnel | grep -B3 10.0.176.64
Tunnel13 is up
    Tunnel source 10.0.192.64/32 (lo0)
    Tunnel destination 10.0.176.64
I can't comment on that - I'm not sure how NSX works
Sorry - maybe I need to understand NSX to understand what you mean by that
Exactly. That command will give you details about the VPC peer, it was never designed to show tunnel destinations.  To see  Dynamic Tunnel End Point (DTEP) destination tunnel addresses on a particular leaf, use:
show isis dteps vrf overlay-1
I'll add some good VPC troubleshooting examples below that I'll steal from this answer I gave some time ago.
But right now, I'm still scratching my head as to WHY you want to know the vPC VTEP? And why you want to view it on a leaf that hasn't received traffic from a source that is connected via the VPC?
VPC CLI Examples
apic1# show vpc map
is a pretty good place to start and
apic1# fabric xxx,yyy show vpc [extended]
is also good (where xxx and yyy are the switch IDs of the VPC pair).
Here are some samples
apic1# show vpc map
Legends:
N/D : Not Deployed
 Virtual Port-Channel Name         Domain  Virtual IP        Peer IP           VPC    Leaf Id, Name                     Fex Id  PC Id   Ports
 T1:L101..102:1:35_VPCIPG          12      10.0.192.67/32    10.0.16.64/32     686    101,Leaf101                               po20    eth1/35
 T1:L101..102:1:35_VPCIPG          12      10.0.192.67/32    10.0.16.66/32     686    102,Leaf102                               po3     eth1/35
 T3:L101..102:1:37_VPCIPG          12      10.0.192.67/32    10.0.16.64/32     345    101,Leaf101                               po2     eth1/37
 T3:L101..102:1:37_VPCIPG          12      10.0.192.67/32    10.0.16.66/32     345    102,Leaf102                               po5     eth1/37
 T4:L101..102:1:38_VPCIPG          12      10.0.192.67/32    10.0.16.64/32     2      101,Leaf101                               po3     eth1/38
 T4:L101..102:1:38_VPCIPG          12      10.0.192.67/32    10.0.16.66/32     2      102,Leaf102                               po6     eth1/38
 T5:L101..102:1:39_VPCIPG          12      10.0.192.67/32    10.0.16.64/32     3      101,Leaf101                               po4     eth1/39
 T5:L101..102:1:39_VPCIPG          12      10.0.192.67/32    10.0.16.66/32     3      102,Leaf102                               po7     eth1/39
 T6:L101..102:1:40_VPCIPG          12      10.0.192.67/32    10.0.16.64/32     344    101,Leaf101                               po1     eth1/40
 T6:L101..102:1:40_VPCIPG          12      10.0.192.67/32    10.0.16.66/32     344    102,Leaf102                               po4     eth1/40
 T7:L101..102:1:41_VPCIPG          12      10.0.192.67/32    10.0.16.64/32     688    101,Leaf101                               po6     eth1/41
 T7:L101..102:1:41_VPCIPG          12      10.0.192.67/32    10.0.16.66/32     688    102,Leaf102                               po9     eth1/41
 T8:L101..102:1:42_VPCIPG          12      10.0.192.67/32    10.0.16.64/32     689    101,Leaf101                               po7     eth1/42
 T8:L101..102:1:42_VPCIPG          12      10.0.192.67/32    10.0.16.66/32     689    102,Leaf102                               po10    eth1/42
and
apic1# fabric 101,102 show vpc extended
 Node 101 (Leaf101)
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 12
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : Disabled
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 7
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
Operational Layer3 Peer           : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1           up     -
vPC status
id   Port   Status Consistency Reason       Active vlans         Bndl Grp Name
2    Po3    up     success     success      2043-2044            T4:L101..102:1:
        38_VPCIPG
3    Po4    up     success     success      -                    T5:L101..102:1:
        39_VPCIPG
344  Po1    up     success     success      2063-2064            T6:L101..102:1:
        40_VPCIPG
345  Po2    up     success     success      2034                 T3:L101..102:1:
        37_VPCIPG
686  Po20   up     success     success      2013-2014            T1:L101..102:1:
        35_VPCIPG
688  Po6    up     success     success      -                    T7:L101..102:1:
        41_VPCIPG
689  Po7    up     success     success      2083-2084            T8:L101..102:1:
        42_VPCIPG
 Node 102 (Leaf102)
Legend:
vPC domain id                     : 12
vPC role                          : secondary
1           up     -
vPC status
2    Po6    up     success     success      2043-2044            T4:L101..102:1:
        38_VPCIPG
3    Po7    up     success     success      -                    T5:L101..102:1:
        39_VPCIPG
344  Po4    up     success     success      2063-2064            T6:L101..102:1:
        40_VPCIPG
345  Po5    up     success     success      2034                 T3:L101..102:1:
        37_VPCIPG
686  Po3    up     success     success      2013-2014            T1:L101..102:1:
        35_VPCIPG
688  Po9    up     success     success      -                    T7:L101..102:1:
        41_VPCIPG
689  Po10   up     success     success      2083-2084            T8:L101..102:1:
        42_VPCIPG
