Existing Switch IOS Upgrade using APIC-EM
paulp317
I would like to upgrade a large amount of Cisco 2960 Catalyst Switches, I used APIC-EM to do the Plug n Play deployment. Is it possible to just do a IOS firmware upgrade on the switches using this solution after they have already been deployed? If so, does the APIC-EM solution force and MD-5 check on the switch side before applying the firmware?
Seb Rupik
Hi there,
In order for the PnP agent to reach out the the APIC-EM controller, it must be in a default factory state. This will mean it has no config. So the only way to upgrade the IOS would be to do deploy it via a Project along with the required running config.
Once a switch has been provisioned you cannot make any further changes to it.
DNAC provides the option you want as part of the lifecycle management.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
