FEX configuration between Nexus 9508 with N2232pp using NX-OS
  i am having 4500 series switches and 6E sup engine.
Then we are having nexus 9508 and N2232PP. when we try to configure fex between these switches.
in Nexus 9508 showing unknown features error.
Current Nx-OS version is n9000-dk9.6.1.2.I2.2.bin.
aniketalashe
Hi Karthikeyan,
FEX support in Nexus 9K is software version dependent. Release notes for 6.1.2.l2.2 do not list support for FEX.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/release/notes/612I22_nxos_rn.html
Release notes for 6.1.2.l2.3 and later releases state "FEX is supported only on the Cisco Nexus 9372PX and 9396PX switches. It is not supported on the other Cisco Nexus 9300 Series switches or the Cisco Nexus 9500 Series switches."
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/release/notes/612I23_nxos_rn.html#pgfId-701747
Suggest you check once with your System Integrator or Cisco contact. Hope this was of help.
Aniket Alashe
jkilleda
Level 3
Level 3
Hello karthikeya,
You can refer to the latest nexus 9000 compatibility with FEX.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/hw/interoperability/fexmatrix/fextables.html#9500
