how can i find that an interface is statically bound with how many EPGs in Cisco ACI.
schnkumar331
Help me to find out the answers.
10 Replies 10
Waruna Rasanga
There are 2 ways to check this,
1. From the APIC GUI
Use this navigation to go the switch interface which you want to check.
Fabric --> <pod Name> --> Node --> Interfaces --> Physical Interfaces --> <Interface (Eth1/1)
in there go to the Deployed EPG tab. In there you can see the statistically allowed VLANs for that interface
2. From the APIC CLI
In the APIC CLI, g to the respective leaf switch interface and enter show run command. in there you can see what are the EPGs which are allowed.
APIC-1# conf t
APIC-1(config)# leaf 201
APIC-1(config-leaf)# interface ethernet 1/1
APIC-1(config-leaf-if)# show run
If that interface is a Port-Channel use bellow command
APIC-1# conf t
APIC-1(config-leaf)# interface port-channel <port-channel name>
if the interface is a VPC use bellow command
APIC-1# conf t
APIC-1(config)# vpc context leaf <leaf node1> <leaf node2>
APIC-1(config-vpc)# interface vpc <vpc name>
Hope this is helpful to answer your question
Waruna
Thanks @Waruna Rasanga
ecsnnsls
If you know the interface that you want to examine, you can use the following REST GET request,
/api/node/mo/topology/pod-1/node-XX/sys/phys-[eth1/1].json?rsp-subtree-include=full-deployment&target-node=all&target-path=l1EthIfToEPg
julian.bendix
Level 4
Level 4
Hey,
you can use the moquery tool on the APIC CLI, like this:
For example, Port 15 on the Leaf with ID 2232..
moquery -c fvStPathAtt | grep dn | grep 'eth1/15' | grep 'node-2232'
Best way I found for this
Let me know if it helps.
BR
Juls
Hi @julian.bendix ,
I thought you may have found something - but for the life of me I can't see the EPG information with the moquery you suggested.
Also, it seems to miss VPCs.
But let us know if you come up with a better solution
Remember: the question is:
"How can i find that an interface is statically bound with how many EPGs in Cisco ACI?"
The answer @schnkumar331 is looking for is a NUMBER, although I think if we found a command that listed the EPGs for an interface (like suggestion #1 from @Waruna Rasanga above) would be close enough (even better perhaps)
RedNectar aka Chris Welsh.
vv0bbLeS
Level 3
Level 3
I will add on to @julian.bendix 's post about moquery, in that I have found that the fvStPathAtt class does not return FEX ports. You could also use the fvRsCEpToPathEp class, but that class will only report the interface if the interface is in the "up" state.
The best class I have found for this is to use the fvIfConn class (Interface Connectivity class), which reports the interface regardless of whether it is "up" or not, and whether it is a FEX port or not:
For example, to return the EPG's for node 291, port 1/3 :
moquery -c fvIfConn | grep dn | grep node-291 | grep eth1/3]
To return the EPG's for node 291, but on FEX 131, port 1/3:
moquery -c fvIfConn | grep dn | grep node-291 | grep extchid-131 | grep eth1/3]
Think of the extchid part as referring to "external chassis id" or "extra chassis id" :- D
0xD2A6762E
@vv0bbLeS ,
Using class fvIfConn is definitely on the right track, but keeping in mind that the question is:
So the answer needs to be a number!
So - now  standing on the shoulders of giants - I'd like to offer @schnkumar331 the following solution:
moquery -c fvIfConn | grep epg- | grep node-291 | egrep -c eth1/3]
You'll see it is the same as @vv0bbLeS ' answer but since the focus is "EPGs", I've replaced dn with epg- and added the -c flag to the last grep to make it count rather than print!
Note that the last ] character on the port number is to prevent the grep finding port 30 as well as port 3
@RedNectar ah yes, good catch! I didn't notice the OP was asking about "how many" :- D  Excellent solution using the -c in egrep!
I will add for the OP's benefit that they can also use the word boundary character in egrep, "\b" to designate the end of a search string. So the end of the above moquery command could also be constructed as egrep -c "eth1/3\b" which will force extended grep (egrep) to stop matching characters after the 3. I mention this as the word boundary character \b in egrep is very useful in many other searching tasks that the OP may run across.
0xD2A6762E
@RedNectar & @vv0bbLeS .. thank you guys for your super nice additions!! That's awesome.
I'll look into that again too and let you know if I can come up with anything else
BR
Jules
This is an amazing solution. I have seen multiple questions regarding this across the forum.
Thank you.
