How can i make a APIC to a factory default ?
thsmfe001
In case fabric domain name mismatch, the mismatched APIC under a APIC cluster can be handled by console and GUI.
I've checked a lot of documents regarding APIC troubleshooting but i couldn't find it.
I think i have to do initial setup to put it on APIC cluster.
Could you tell me What i should do?
16 Replies 16
If the APICs were ever successfully converged into a cluster, rescue-user will use the password of the cluster. if the APICs never formed a cluster then rescue-user will not have a password if I'm not mistaken, so yes i believe that would solve your problem.
If you noticed during the initial setup script, only APIC-1 asked for a password, subsequent APICs are assumed to become cluster members after fabric discovery and password is exchanged to all other APICs for local authentication purposes. if the fabric is never discovered and the APICs do not negotiate the password, then rescue-user will not have a password.
I appreciate your correct response.
Thanks to you ,i can step up ACI PoC for a Service Provider.
Thank you for your cooperation.
Have nice day.
