How to convert routed port to switched port in ACI - Leaf
m7mmd3bbas
Hi Folks,
This is my first contribution to the great cisco community and hope to get my question answered.
Now, i have two leafs with 1, 10, and 25 G server ports and 40 & 100 G fapric ports.
I want to use 2 fabric ports as VPC connecting to the FW.
Is there a way to do that?
Thanks in advance for your answers.
Hi @m7mmd3bbas
I am sure TAC is quite busy with network down cases ^_^
My mistake about the previous post. Idk why I mentioned the Fabric button.. The one you need to use is the "Downlink". (the buttons are grayed out to such a degree that they are barley visible).
Few details about the Downlink convertion:
How to use: Convert uplinks to downlinks here in a port profile. Choose the switch. Click an eligible port, and then click Uplink or Downlink and click Submit. Reload the switch for the change to take effect.
Rules about Uplink/Downlink Restrictions
  • This functionality is supported on the following Cisco switches:
    • N9K-C9348GC-FXP
    • N9K-C93180LC-EX and N9K-C93180YC-FX
    • N9K-93180YC-EX, N9K-C93180YC-EX, and N9K-C93180YC-EXU
    • N9K-C93108TC-EX and N9K-C93108TC-FX
  • The last two ports have to be uplink ports.
    The maximum number of uplinks varies depending upon the type of switch.
    For N9K-C9348GC-FXP, N9K-C93108TC-EX, N9K-C93108TC-FX, ports with operating speed of 1G cannot be changed from uplink to downlink.
    For N9K-C93180LC-EX, all the even ports (for example, 2, 4, 6… 28, 30, 32), ports 29 and port 31 cannot be converted.
Hope it helps,
Sergiu
11 Replies 11
Sergiu.Daniluk
Hi @m7mmd3bbas
Welcome to the Cisco Community! ^_^
You can change the uplink ports (40/100G ports) to downlink on the leaf, from:
Fabric -> Inventory -> Pod X -> Leaf X (click on the leaf name) -> Interface tab -> Change the mode to "Configuration" in the right corner, select the desired port(s), then click on "Downlink" to change it's operational usage. In my case I do not have any eligible ports for donwlink conversion, but the Downlink button is next to the highlighted Fabric port.
EDIT:
How to use: Choose the switch. Click an eligible port, and then click Uplink or Downlink and click Submit. Reload the switch for the change to take effect.
    • N9K-C9348GC-FXP
Stay safe,
Sergiu
P.S. Don't forget to mark answers as correct if it answers your question or if it solves your problem!
m7mmd3bbas
Hi @Sergiu.Daniluk ,
Thanks a lot for your quick response. It is faster than the TAC
Although your solution showed me a good place to do important config, i couldn't find an option to downlink the fapric port to work as regular server port in order to configure VPC.
Hope below screenshot can help:
(i want the configuration of port 58 [fapric port] to be the something like 46 [server port])
Thanks again and truly appreciate your feedback.
BR
Hi @m7mmd3bbas
    • N9K-C9348GC-FXP
Hope it helps,
Sergiu
I could not thank you enough @Sergiu.Daniluk ..
I am wondering if you got any chance to work on ACI sim 4.26h ! ... in order to downgrade a leaf port, a reboot is required. If i restart the ESXI VM, the whole setup is wiped and i have to do it again .
Any thoughts?
BR
Are you trying to modify an Uplink/Downlink of a virtual Leaf within a Sim?
Robert
Hi @Robert Burns
yes i do ... wondering if there is a way?!
thnx
Thank you for your answer @Sergiu.Daniluk . I know this post is a bit old but I'm wondering if there is a way to do this in an automated way. We would like to change on all of our leaf switches port 1/51-52 as downlink and I wanted to write an ansible playbook for it. The problem is I can't figure out which module/path should I use to accomplish this via API.  Normally I use API inspector in such cases but when I configure an uplink port as a downlink, there isn't any post request appearing in API inspector. If somebody can help me with this I will be grateful. Thanks in advance.
Regards.
Hi @O.K.
Yeah, it looks like you cannot change that from API.
I have tried this:
method: POST
URL: https://{{apic_ip}}/api/mo/topology/pod-1/node-201/sys/ops/slot-lcslot-1/portpol-49.json
body:
    "eqptPortP": {
        "attributes": {
            "ctrl": "uplink",
            "dn": "topology/pod-1/node-201/sys/ops/slot-lcslot-1/portpol-49"
response:
    "totalCount": "1",
    "imdata": [
            "error": {
                "attributes": {
                    "code": "170",
                    "text": "Admin implicit props cannot be modified, class=eqptPortP, prop=ctrl"
However, you can do this change via CLI of APIC:
apic3# conf
apic3(config)# leaf 201
apic3(config-leaf)# interface ethernet 1/50
apic3(config-leaf-if)# port-direction downlink
You can even use ranges for leafs: leaf201-202
Take care,
Sergiu
Thank you once again for your time!
I think I have just found the solution today, it was cumbersome but here it is:
The solution is actually documented here but the problem was I wanted to use a JSON request but it didn't work until I found this issue on GitHub so I wrote the req. like this and it worked.
 - name: Change the interface as down/uplink
    aci_rest:
      hostname: "{{ inventory_hostname }}"
      username: "{{ansible_user }}"
      password: "{{ ansible_password }}"
      validate_certs: False
      path: "/api/node/mo/uni/infra/prtdirec.json"
      method: post
      content: {
                "infraRsPortDirection":{
                  "attributes":{
                    "tDn":"topology/pod-{{pod_id}}/paths-{{node_id}}/pathep-[eth1/52]","direc":"DownLink"
Oguz
Nice!
m7mmd3bbas
thnx
