How to view BGP properties info for specific host in Cisco APIC via CLI/SSH?
fc00::/7
Here is how to get BGP info in a host in Cisco APIC via GUI/HTTPS.
APIC > Fabric > Inventory > POD 1 > (any) Host > Protocol > BGP
APIC-Fabric
Please take note that this image is taken from http://cdn.techgenix.com/media/promos/APIC-Fabric.JPG
Therefore, I can't expand the POD 1 and browse to (any) Host > Protocol > BGP
Would it possible to get the same info (Host's BGP properties) via CLI/SSH?
If yes, what is the command?
Sergiu.Daniluk
In GUI, you can find the BGP under each Leaf (not host) where you have BGP configured:
If you want to see the BGP info from CLI, you can use NX-OS BGP command, directly from leaf CLI.
From ibash:
Leaf101# show bgp ...
Leaf101# show ip bgp ...
Or from NXOS shell:
Leaf101# exit
Leaf101# vsh
Cisco iNX-OS Debug Shell
This shell should only be used for internal commands and exists
for legacy reasons. User should use ibash infrastructure as this
will be deprecated.
Leaf101# show ip bgp ?
  A.B.C.D            Display one particular network from the BRIB in detail
  A.B.C.D/LEN        Display one particular prefix from the BRIB in detail
  all                Display BGP information for all address families
  community          Display routes matching the BGP communities
  community-list     Display routes matching the community-list
Cheers,
Sergiu
