HTTPS web page not loading
LewisD1
Hello All,
I am experiencing a weird issue in my Multipod ACI Deployment.
We will have 2 machines part of the same EPG/BD.
Machine 1 and Machine 2
Machine 1 is in Pod 1
Machine 2 is in Pod 2
From machine 1 we can ping, ssh, telnet and telnet on port 443  to machine 2 without issue. When we try to load machine 2 in a web browser on port 443 we just get this page cannot be displayed. If machine 1 and machine 2 are in the same pod it all works perfectly.
We are running version 5.2(3f)
We are not restricting Intra-EPG traffic
I have tried disabling VRF enforcement to rule that out but still the same.
I am drawing up a blank.
17 Replies 17
@Robert Burns
I kept digging i could not get anything past over 1450MTU. It turns out that the Subinterfaces of the IPN devices had the default MTU of 1500. All other interfaces has 9126. I have changes the sub interfaces which then brought everything into life.
You hit the nail on the head.
Thank you for your help.
Lewis
Great to hear.  Since telnet worked fine (lower payload) figured a full web connection would exhibit this symptom if there was fragmentation.
Cheers,
Robert
Since we are talking about unicast traffic (https), not sure why focus should be on mcast config in IPN.
@LewisD1  I would continue with the packet captures on ACI Leaf/Spines (use ELAM Assistant) and confirm first where the traffic is seen/not seen.
Since you already confirmed that the EP from Pod2 receives and responds, then continue with a captures in Pod2 (direction EP->Leaf->Spine, Source EP-Pod2 Destination EP-Pod1). Then make the same captures on Spines/Leafs in Pod1.
Cheers,
Sergiu
