ā05-01-2023 03:44 PM
I am looking for a model number of a hybrid copper/fiber switch that will operate in elevated temperatures. The use is for remote cameras and IP phones over 100 meters away in a manufacturing environment, with no remote IDF room. A Hoffman rack is intended to house the switch.
Is there a product that will work in this situation?
ā05-01-2023 04:05 PM
Hello
You may take a look here. Model Cisco CatalystĀ® IE3400 for example, support up to 75 degree celsius
https://www.cisco.com/site/us/en/products/networking/industrial-switches/index.html
ā05-01-2023 04:06 PM
How much power draw does each camera and IP phone require?
ā05-02-2023 12:58 PM
hello,
The expected max is 30 watts.
ā05-02-2023 03:51 PM
Don't make presumption and get the fact straight.
Now, how much power draw are the PED pulling?
ā05-02-2023 05:02 PM
Perfect!
cameras max 17 watts with IR
IP phone 25 w max or 802.3at by spec, has a light attached
ā05-02-2023 06:46 PM
Whao. That phone is a power hog!
The only thing that I can think of is get a 4-port Cisco Microswitch. The switch will need to be connected using fibre optic and locally powered up.
ā05-03-2023 03:33 PM
Yes, that phone can be. If local power is available to the phone, there is no need for POE, just data. The phone is a blue light call box. These are out some 500 ft from the data room. I love that switch suggestion. I didn't know it was available, very nice piece! There are ongoing discussions on how to get a network there and distribute it to the few devices needed. It is the perfect story of design by a committee.
ā05-03-2023 05:09 PM
OMfG.
ā05-03-2023 04:06 PM
use cisco switch selector and try match match your requirement
