Interface output error
suneq
Level 3
Level 3
Hi all,
We are facing a slowness issue for many servers connecting to our ACI fabric, it seems that there is some packet loss.
When we checked the interfaces connecting to the servers, we saw many output errors/drops
We read the following article:
 https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/application-policy-infrastructure-controller-apic/210539-Explanations-of-Packet-Drop-Faults-in-AC.html
and found that
If we understood correctly it talked about input drops, but how about output drops? What can cause output errors/drops (we checked the bandwidth but it was fine)?
Any advice will be highly appreciated.
joezersk
Hello.  In APIC, are you seeing this fault? F119936
If yes, then it is likely cosmetic.  Check the link below for further detail.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/troubleshooting/b_APIC_Troubleshooting/b_APIC_Troubleshooting_appendix_011010.html
Hi joezersk,
Thank you for the interesting information. However, I do not see that fault in the APIC.
Do you have any other ideas?
Thanks.
