Is it possible to direct a ping command to a particular VRF on the N9K / ACI command line ?
bruceclounie
In troubleshooting an L3 out connection to an external router,  I would like to direct a ping out a particular VRF to verify connectivity.
With most routers,  you can specify a source IP or interface for the ping.   With the N9K in ACI mode with an Out-of-Band address,  it appears that issuing a ping command from the command line will direct it out the management interface.  I can see this by issuing a traceroute from the command line.
I have issued a ping in this matter,  but is does not seem to make any difference.   ping 10.255.118.27 vrf common:Common-VRF
Is there a way to direct a ping out through a particular VRF ?
thanks,
2 Accepted Solutions
Zach Seils
Level 7
Level 7
Hi Bruce,
You can use the iping command to specify the VRF information.
Zach
Robert Correiro
Hi bruceclounie,
You can source a ping from a particular VRF on a Leaf using the iping command. Here's the usage:
leaf# iping -h
usage: iping [-dDFLnqRrv] [-V vrf] [-c count] [-i wait] [-p pattern] [-s packetsize] [-t timeout] [-S source ip/interface] host
In your case the command would be:
leaf# iping 10.255.118.27 -V common:Common-VRF
Hope this helps.
7 Replies 7
Zach Seils
Level 7
Level 7
Hi Bruce,
Zach
Robert Correiro
Hi bruceclounie,
leaf# iping -h
Hope this helps.
Is there an equivalent command for traceroute ?
Yes, itraceroute and itraceroute6 both exist. In the below output, I've hit the 'ESC' key twice to list the options.
leaf2# itraceroute
 A.B.C.D   Enter destination IP
 A:B::C:D  Enter destination IPv6
 external  Run itraceroute with 5-Tuple
 src-ip    Source EP IP
leaf2# itraceroute6
Example:
SYNTAX:  itraceroute target_ip vrf source_tenant:ctx
leaf4# itraceroute 62.1.1.40 vrf common:deadbeef-net1
Tenant traceroute to 62.1.1.40, tenant VRF common:deadbeef-net1, source encap vlan-61, from [65.1.1.1], payload 56 bytes
Path 1   [ Complete ]   [ internal ]
   1: TEP     10.0.192.93  intf   eth1/4  1.014 ms
   2: TEP     10.0.192.90  intf unspecified  3.471 ms
Path 2   [ Complete ]   [ internal ]
   1: TEP     10.0.192.94  intf   eth1/4  0.942 ms
   2: TEP     10.0.192.90  intf unspecified  3.577 ms
Tomas,  thank you very much !
Tomas de Leon
Example
leaf4# show vrf
 VRF-Name                           VRF-ID State    Reason
 common:deadbeef-net1                    5 Up       --
 common:deadbeef-net2                   11 Up       --
 common:deadbeef-net3                    6 Up       --
leaf4# show endpoint vrf common:deadbeef-net1
      VLAN/                           Encap           MAC Address
      Domain                          VLAN            IP Address
common:deadbeef-net1                        vlan-61        65.1.1.100 L
common:deadbeef-net1                        vlan-60        61.1.1.100 L
common:deadbeef-net1                        vlan-63        63.1.1.100 L
leaf4# show endpoint vrf common:deadbeef-net2
common:deadbeef-net2                        vlan-69         62.1.1.40 L
common:deadbeef-net2                        vlan-69         62.1.1.41 L
common:deadbeef-net2                        vlan-69         62.1.1.42 L
leaf4# show ip interface vrf common:deadbeef-net1
IP Interface Status for VRF "common:deadbeef-net1"
vlan9, Interface status: protocol-up/link-up/admin-up, iod: 128,
  IP address: 65.1.1.1, IP subnet: 65.1.1.0/24
  IP broadcast address: 255.255.255.255
  IP primary address route-preference: 1, tag: 0
vlan11, Interface status: protocol-up/link-up/admin-up, iod: 136,
  IP address: 61.1.1.1, IP subnet: 61.1.1.0/24
vlan12, Interface status: protocol-up/link-up/admin-up, iod: 137,
  IP address: 63.1.1.1, IP subnet: 63.1.1.0/24
leaf4# iping
Vrf context to use [management] : common:deadbeef-net1
Target IP address or Hostname : 62.1.1.40
Repeat count [5] :
Datagram size [56] :
Timeout in seconds [2] :
Sending interval in seconds [2] :
Extended commands [no] : yes
Source address or interface : 63.1.1.1
Data pattern [0xabcd] :
Type of service [0] :
Set DF bit in IP header [no] :
Time to live [255] :
Sweep range of sizes [no] :
Sending 5, 56-bytes ICMP Echos to 62.1.1.40 from 63.1.1.1
Timeout is 2 seconds, data pattern is 0xABCD
64 bytes from 62.1.1.40: icmp_seq=0 ttl=63 time=0.317 ms
64 bytes from 62.1.1.40: icmp_seq=1 ttl=63 time=0.404 ms
64 bytes from 62.1.1.40: icmp_seq=2 ttl=63 time=0.32 ms
64 bytes from 62.1.1.40: icmp_seq=3 ttl=63 time=0.369 ms
64 bytes from 62.1.1.40: icmp_seq=4 ttl=63 time=0.278 ms
--- 62.1.1.40 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.278/0.337/0.404 ms
leaf4# iping -V common:deadbeef-net1 -S 63.1.1.1 62.1.1.40
PING 62.1.1.40 (62.1.1.40) from 63.1.1.1: 56 data bytes
64 bytes from 62.1.1.40: icmp_seq=0 ttl=63 time=0.414 ms
64 bytes from 62.1.1.40: icmp_seq=1 ttl=63 time=0.365 ms
64 bytes from 62.1.1.40: icmp_seq=2 ttl=63 time=0.245 ms
64 bytes from 62.1.1.40: icmp_seq=3 ttl=63 time=0.338 ms
64 bytes from 62.1.1.40: icmp_seq=4 ttl=63 time=0.306 ms
round-trip min/avg/max = 0.245/0.333/0.414 ms
