JSON script to get topology info on fabric layout
adolfo.cadillo
I am looking for a JSON script that someone has already made so I can reverse engineer an ACI fabric design that someone has implemented but has not documented it.  I need basically an assessment script of this person ACI network.   Does such a script exist?
Sergiu.Daniluk
Hi Adolfo,
Since the fabric topology is standard (CLOS/Spine-Leaf), is not much you can render there, however there are two apps which can help you a visual of the tenant config, plus contract design:
1. https://dcappcenter.cisco.com/policy-viewer.html - policy viewer for tenant config
2. https://dcappcenter.cisco.com/contract-viewer.html - contract viewer for, as the name indicates, contract config
Both can be installed directly on APIC.
Stay safe,
Sergiu
Awesome, thank you!!  I will try them out.
