L3out with MSO
alanjames9
Hey Guys,
When creating a L3out with ACI Multi-site to communicate outside of the fabric, is this done within the APIC and not the MSO?
Is the L3out configuration within the MSO just relating to inter-site communication across evpn bgp ?
Sergiu.Daniluk
L3Out can be configured both from APIC and from MSO. However, configuring it from MSO it expends the 'visibility' of the object across sites. Also, if you want your L3Out to be an inter-site L3Out, you need to configure it from MSO. See this from further details about inter-site MSO: https://unofficialaciguide.com/2020/05/10/intersite-l3out-with-cisco-aci-multisite-fabrics/
Stay safe,
Sergiu
Hey there, thanks for the reply.  I can see you can add the L3out in MSO, but there is no option to add logical node profiles/interfaces/ipaddress/ospf etc/.
