Layer 2 device insertion
dodgerfan78
Level 5
Level 5
Hi, is it possible to do put a layer 2 device such as a transparent FW in between 2 EPGs? I am trying it but unable to get it to work. It could be my VM that is acting as L2-FW however.
webvm----webepg----eth0[FW]eth1----appepg----appvm
My ARP packets from webvm never get to the appvm.
Is this possible? Has anyone done this? I set all the BD options to Flood where possible.
Bryan
Nik Noltenius
Hi Brian,
I doubt my ability to help but out of curiosity: How are you trying to achieve that right now?
Correct me if I'm wrong but I understand that you have two EPGs webepg and appepg. You have a VM with it's vnic attached to the webepg port-group and a VM with it's vnic attached to the appepg port-group. Now you also have a FW-VM which has interfaces both in the one and in the other port-group and that is configured to transparently bridge between those two interfaces.
So far, so good. Now wouldn't you need a contract between webepg and appepg and if so wouldn't that automatically lead to all allowed traffic going back and forth directly without ever hitting the FW-VM?
I don't understand how you force traffic to go through the FW. If I get that obstacle out of the way I could try to recreate your setup in our lab and maybe figure something out.
Nik
Hi Nik,
It should work with out contracts because the traffic is stitched between the two epgs by the firewall, not directly by the fabric. The web-vm will arp for the app-vm mac address. The arp will hit the FW, get bridged to the app-epg and hit the app-vm. The app-vm response will hit the app-epg interface of the fw and get bridged back to the web-epg where the web-vm will hear it. Then unicast flow can continue (I think).
-Bryan
Jason Williams
Level 8
Level 8
The ACI configuration would depend upon your network design.
1. Is the WebVM (EPG) and AppVM (EPG) in the same subnet?
2. Is there a bridge between FW Eth0 and Eth1?
If the answer is yes to both of these questions then you would need to configure 2 bridge domains. 1 for inside and 1 for outside.
BD-1 configuration:
Unicast routing = disabled
Unknown unicast = flood
BD-2 configuration:
BD-1 (inside) should contain WebVM and FW-Eth0
BD-2 (outside) should contain AppVM and FW-Eth1
If you were to place everything into the same BD, then you would see MAC flap issues. ACI would learn WebVM MAC between the WebVM and FW-Eth1. Same goes for AppVM MAC being learned on AppVM and FW-Eth0.
Splitting the inside and outside into 2 BDs would create separate L2 domains (MAC address tables).  ACI will still learn the WebVM MAC address on WebVM and FW-Eth1, but two different MAC tables. Same applies to the AppVM MAC.
I would advise looking into Service Graph Design White Paper. Although you're probably not integrating service graphs, this guide still contains useful information about L2/L3 configurations for inserting firewalls.
Service Graph Design with Cisco Application Centric Infrastructure White Paper
