Hello there @suneq
Within you current situation i would suggest you to open a tac case and get some assistance.
However here are some steps you can take.
Check the APIC via cli to see what / double check the status of the leaf using acidiag fnvread
Try performing a clean reboot of the leaf node, log in to the node (by what you mentioned you might need to go via console) and execute the following:
>setup-clean-config.sh
>reload
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out Cisco ACI ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
