Leaking Between L3Out
ferdy.rizaldy
I have some questions about ACI
I have 2 L3Out in single tenant
Tenant 1 :
L3Out 1 -> private network (vrf) blue -> router 1
L3Out2 -> private network (vrf) green -> router 2
How to leaking between them ?
Please Advice
lpember
Hi Ferdy,
Transit Routing between two VRFs in ACI is not supported at this time. You can refer to this guide for more info:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_KB_Transit_Routing.html#concept_CBBCBA5750D84E4BB49CD727FDCF547A
Is there a specific use-case you have for this? I suspect there are other ways for you to accomplish what you would like to do.
Hi Ipember,
Yes i have some case, i want design like this :
Server 1 -> epg 1 -> BD red -> vrf Red
Server 2 -> epg 2 -> BD white -> vrf white
L3Out 1 -> private network (vrf) blue -> router 1 -> internet 1
L3Out2 -> private network (vrf) green -> router 2 ->MPLS
My goal is server 1 and 2 can reach from internet and MPLS (visaversa) and all server in epg 1 and 2 can communicate
Can i deploy this design with cisco ACI ?
Please Advise
Hi ferdy,
Do the servers need to be in separate VRFs? From your example, it seems like you would be better served by putting everything in a single VRF on ACI. You can have 2 L3 External connections from VRF Red, and then all the BDs and EPGs reside in VRF Red.
yes i make separate the VRF between Productions and Development server and L3out i make separate because this is connections to external i.e another router for WAN and Internet
