Migrating virtual Nexus Dashboard to physical Nexus Dashboard?
SIMMN
Say I build a virtual nexus dashboard cluster with NDO. I now need to migrate the NDO into a physical nexus dashboard cluster running the same software version. I have not found any document to say if it would be supported...
So has anyone done this before? Will the backup&restore process be supported for this use case?
0 Replies 0
