MSO -> APICs template verification authorization issues after MSO upgrade
goranje
We did upgrade on MSO from version 2.2.4 to version 3.1.1 and it seems to be successful on MSO application level. Deployment of new configuration to APIC seems to be OK, but we have issue with template verification.
When I start verify on shared template in all existing schemas the verification for one site is finishing quickly and successful but for other site it took a lot of time for response and the response is:
Succesfully deployed.
Verification error: Unauthorized: APIC token for https://xxx.xxx.xxx.xxx timed out
Template is unverified.
The xxx.xxx.xxx.xxx is the IP address from second APIC.
For test we shut down the second APIC to see if the verification will be ok for other APICs but in that case we receive same error but with IP address from third APIC.
Do some have some experience with this issue?
Any idea how can we fix the error and have successful verification?
Best regards,
Korth501
Did you ever solve this issue?
Greetings,
Bob
This issue can be due to an issue with the pyquery service.  Easiest way to workaround it would be to restart each APIC (one at a time) for the problem site, then attempt to re-validate the Schema.
Robert
