MSO Node Join Faild.
[root@node3 prodha]# ./msc_cfg_join.py SWMTKN-1-3ko2wt94x3u6q2tzk0zyzi6m5qdw92s0ekgx2005ij5folkrdr-2uju9jrioxbl9ahpyo97oq81h x.x.x.x:2377 2019-11-09 06:21:09,569 INFO [msc_cfg_join:37]: Error response from daemon: Timeout was reached before node joined. The attempt to join the swarm will continue in the background. Use the "docker info" command to see the current swarm status of your node.
i have three nodes in my mso setup and i have installed two nodes successfully. when im going to install my 3rd node this error comes.
network connectivity and firewall ruls are ok.ping also working from all nodes to each other. can anyone give the idea regards of this,
0 Replies 0
