Multi-pod, multi-node service graph?
tuanquangnguyen
Level 4
Level 4
Hi folks,
Trying to understand the concept of multi-node service graph with mixed L3 and L1/L2 in a multi-pod environment.
In a N-S contract with two-node:
- Does Pod-ID Aware still apply to the second node? As in, I'd like the traffic to be service-chained to the same pod's PBR nodes as the endpoint, is it applicable?
In a E-W contract with two-node:
- Is there anyway that does not cause traffic tromboning?
- If the first node in one pod fails and it has to rely on its backup policy to redirect to the first node of the other pod, can I use health group to also have the second node failover to the other pod as well?
0 Replies 0
