Multi Site Orchestrator Installation
asanga
We are installing Multi site Orchestrator as part of ACI Multi site deployment. In our VM environment we have space only for 1VM MSO. Is it mandatory to deploy all 3 MSO VM before doing any sort of ACI multi site configuration ? We are planning to upgrade our VMware environment to have more space to deploy more applications. So until that happen, can I deploy only 1 MSO VM and start doing Multi Site Configuration ? Once VMware environment Upgrade process complete, I intend to install 2 remaining MSO . Is this possible ?
As Per my knowledge i think its better if you can install the all 3 MSO
nodes. When you install the first node it will the master node. so when you
are going to install other two VMs you should have the key also which is
generated by the master node.
If you haven't possibility install all the 3 nodes at lease in one ESXI
host its better keep the all information.
But I have no experience with single MSO node operation. but i'm sure it
should work and it would not be a big problem.
Keep remember when you installing other three nodes give the correct master
node key to other nodes. when that happens in order nodes will sync
automatically..
Use this command for the service verification.
*docker service ls*
