Overlapping External TEP IPs on loopbacks within a Multi-Pod
Danny Koenig
Hi guys,
within my Multi-Pod (2 Pods) environment I got an overlapping IP which belongs to the external TEP-Pool from Pod 2. This fabric is not in production yet.
Informations:
  • external TEP-Pool Pod 2: 172.20.12.0/24
  • Data Plane IP: 172.20.12.1
  • Spine 221 IP: 172.20.12.2
  • Spine 222 IP: 172.20.12.3
Fault F1425 raised:
# fault.Inst
code             : F1425
ack              : no
alert            : no
annotation       :
cause            : ip-provisioning-failed
changeSet        : ipv4CfgFailedBmp (New: ipv4:Addraddr_failed_flag,ipv4:Addrctrl_failed_flag,ipv4:AddrlcOwn_failed_flag,ipv4:AddrmodTs_failed_flag,ipv4:AddrmonPolDn_failed_flag,ipv4:Addrpref_failed_flag,ipv4:Addrtag_failed_flag,ipv4:Addrtype_failed_flag,ipv4:AddrvpcPeer_failed_flag), ipv4CfgState (New: 1), operStQual (New: subnet-overlap)
childAction      :
created          : 2025-07-23T18:13:28.259+02:00
delegated        : no
descr            : IPv4 address(172.20.12.2/32) is operationally down, reason:Subnet overlap on                          node 221                           fabric hostname ZDITBSW221-SP
dn               : topology/pod-2/node-221/sys/ipv4/inst/dom-overlay-1/if-[lo6]/addr-[172.20.12.2/32]/fault-F1425
domain           : access
extMngdBy        : undefined
highestSeverity  : major
lastTransition   : 2025-07-23T18:15:30.654+02:00
lc               : raised
modTs            : never
occur            : 1
origSeverity     : major
prevSeverity     : major
rn               : fault-F1425
rule             : ipv4-addr-oper-st-down
severity         : major
status           :
subject          : oper-state-err
title            :
type             : operational
uid              :
userdom          : all
Loopback Interfaces on Spines
Spine 221:
lo0                  172.24.164.66/32     protocol-up/link-up/admin-up
lo1                  172.20.12.1/32       protocol-up/link-up/admin-up
lo2                  172.20.12.2/32       protocol-up/link-up/admin-up
lo3                  172.24.0.64/32       protocol-up/link-up/admin-up
lo4                  172.20.12.229/32     protocol-up/link-up/admin-up
lo5                  172.20.12.230/32     protocol-up/link-up/admin-up
lo7                  172.24.128.33/32     protocol-up/link-up/admin-up
lo8                  172.24.128.34/32     protocol-up/link-up/admin-up
lo9                  172.24.128.35/32     protocol-up/link-up/admin-up
lo10                 172.24.0.66/32       protocol-up/link-up/admin-up
lo11                 172.24.192.70/32     protocol-up/link-up/admin-up
lo12                 172.24.0.65/32       protocol-up/link-up/admin-up
lo13                 172.24.192.69/32     protocol-up/link-up/admin-up
lo14                 172.24.192.71/32     protocol-up/link-up/admin-up
Spine 222:
lo0                  172.24.164.64/32     protocol-up/link-up/admin-up
lo2                  172.20.12.3/32       protocol-up/link-up/admin-up
lo6                  172.20.12.2/32       protocol-up/link-up/admin-up
lo10                 172.24.0.65/32       protocol-up/link-up/admin-up
lo11                 172.24.192.65/32     protocol-up/link-up/admin-up
lo12                 172.24.0.66/32       protocol-up/link-up/admin-up
lo13                 172.24.192.66/32     protocol-up/link-up/admin-up
lo14                 172.24.192.67/32     protocol-up/link-up/admin-up
Output from the APIC (moquery -c ipv4Addr):
# ipv4.Addr
addr             : 172.20.12.2/32
childAction      :
ctrl             :
dn               : topology/pod-2/node-221/sys/ipv4/inst/dom-overlay-1/if-[lo2]/addr-[172.20.12.2/32]
ipv4CfgFailedBmp :
ipv4CfgFailedTs  : 00:00:00:00.000
ipv4CfgState     : 0
lcOwn            : local
modTs            : 2025-07-23T18:13:29.721+02:00
monPolDn         :
operSt           : up
operStQual       : up
pref             : 0
rn               : addr-[172.20.12.2/32]
status           :
tag              : 0
type             : primary
vpcPeer          : 0.0.0.0
# ipv4.Addr
childAction      :
ctrl             :
ipv4CfgFailedBmp : ipv4:Addraddr_failed_flag,ipv4:Addrctrl_failed_flag,ipv4:AddrlcOwn_failed_flag,ipv4:AddrmodTs_failed_flag,ipv4:AddrmonPolDn_failed_flag,ipv4:Addrpref_failed_flag,ipv4:Addrtag_failed_flag,ipv4:Addrtype_failed_flag,ipv4:AddrvpcPeer_failed_flag
ipv4CfgState     : 1
lcOwn            : local
modTs            : 2025-07-23T18:13:27.150+02:00
monPolDn         : uni/fabric/monfab-default
operSt           : down
operStQual       : subnet-overlap
pref             : 0
status           :
tag              : 0
type             : primary
vpcPeer          : 0.0.0.0
# ipv4.Addr
childAction      :
ctrl             :
dn               : topology/pod-2/node-222/sys/ipv4/inst/dom-overlay-1/if-[lo6]/addr-[172.20.12.2/32]
ipv4CfgFailedBmp :
ipv4CfgState     : 0
lcOwn            : local
modTs            : 2025-07-23T18:13:25.032+02:00
operSt           : up
operStQual       : up
pref             : 0
status           :
tag              : 0
type             : primary
vpcPeer          : 0.0.0.0
How can this be fixed? Found no hint.
Thank you very much!
Cheers,
Danny
5 Replies 5
Danny Koenig
Workaround: Assigning another IP from ext. TEP-Pool, error will be cleared. But 172.20.12.2 is still in use.
How to clean this up and as the IP concept says?
Actually had the same problem after upgrading to 6.1(2g) and also assigned a different IP to one of the spines
How did you assign another IP from the ext. TEP-Pool?
u need to assign  the new adress in corresponding Logical Node Profile of the IPN L3-Out:
go to "Tenants -> infra -> Networking -> "IPNL3Out" -> Logical Node Profiles -> "NodeX" and change the loopback adress
sk37
Frequent Visitor
Frequent Visitor
.1 is the dataplane TEP and .2 is the Unicast TEP. Unicast TEP is hidden. If you uncheck the "use default" during the multi-pod build-up phase, then the unicast TEP is visible. Therefore, you cannot use the first two IPs for any node's loopback IP.
