Hi guys,
I can ping a subnet's (pervasive) gateway (from externally attached routed domain) that is defined in the common tenant but when I use that L3out (leak) EPG as a shared L3out from another tenant I cannot reach the same GW via ICMP (routes are all exported and there), the EPs in the same subnet are reachable in both cases. The EPs in the subnet can always reach that GW. Is that expected behaviour? Running APIC 1.3(2o), NX-OS 11.0.
best,
P
