PIM-Sparse Mode in Cisco ACI
netbeginner
Level 2
Level 2
Hi All,
Which L3out mode (Routed, Sub-Interface , SVI) supports PIM-SM for multicasting and what is the limitation.
Rgds
Sergiu.Daniluk
Hello buddy,
According to config guide:
PIMv4/PIM6 is supported on Layer 3 Out routed interfaces and routed subinterfaces including Layer 3 port-channel interfaces. PIMv4/PIM6 is not supported on Layer 3 Out SVI interfaces.
All limitations (for ACI 5.1) are listed here: https://www.cisco.com/c/en/us/td/docs/dcn/aci/apic/5x/l3-configuration/cisco-apic-layer-3-networking-configuration-guide-51x/m_ip_multicast_v2.html
For previous versions, search for Layer3 configuration guide in here  https://www.cisco.com/c/en/us/support/cloud-systems-management/application-policy-infrastructure-controller-apic/tsd-products-support-series-home.html#Configuration_Guides
then select the IP Multicast section.
Stay safe,
Sergiu
Sergiu.Daniluk
Hello buddy,
Stay safe,
Sergiu
