Problems with vsh -c commands into a Python Script
Rafael85
Visitor
Hello Network,
i implement a script in order to speed up the interaction with the TAC. I'm able to send normals show commands over a python script (attached) but when they request me a vsh -c output the script always fail.
this is a output example of the error (cmd example vsh -c 'show logging onboard internal reset-reason')
vsh -c "show logging onboard internal reset-reason"
Error: Invalid argument 'vsh -c show logging onboard internal reset-reason '. Please check syntax in command reference guide
Thank you for the help!
2 Accepted Solutions
Rafael85
Visitor
Sry i know the issue, the vsh commands should be used on the leafs/spines and not in the apics.
close the ticket.
@Rafael85 ,
The ONLY person who can "close the ticket" - as you say is YOU
The way you do this is to mark the answer that solved your problem as correct by clicking the Accept as Solution option you'll see at the end of each answer given to your question.
RedNectar aka Chris Welsh.
5 Replies 5
 The command syntax is:
show logging onboard module slot  internal reset-reason
Rafael85
Visitor
close the ticket.
@Rafael85 wrote:
close the ticket.
For your information, just to avoid further confusion on your side, there are not tickets to close. This is a community forum where you can search for info or solutions to your problems, ask questions, get answers from your peers from the industry or even cisco employees sure. But there are no tickets.
Stay safe,
Sergiu
Yeah sorry, my first time in this forum. Sorry for the miss understanding
@Rafael85 ,
