Retrieval of routing information and interfaces
valentik
Today I have 3 APICs and 70 leafs on my infrastructure. I need to retrieve routing information and interfaces in a text file.
To put it simply, how to do an old "show ip route" and "show ip interface" on ACI?
On which equipment should I perform this request (APIC, Tenant, Leaf)?
Is it possible to do this through Ansible and the cisco.aci collection?
Do you have any code example?
Thanks in advance
Valentino
Sergiu.Daniluk
in the newer version of ACI (I have 5.2.2f) it looks like you can see the routing table, per VRF, in the GUI, and it also shows the nodes where the route is present: Tenant-name -> VRF-name -> Operational -> Route table:
Cheers,
Sergiu
6 Replies 6
Sergiu.Daniluk
Hi @valentik
Remember that behind the "ACI" cloud, there Nexus 9000 switches are still L3 switches, running a fairly similar operating system as the original NX-OS.
In other words, you can attach to the leaf you are interested and run the following commands to check the routing info:
show vrf
show ip route vrf <VRF-NAME>
Note: you will see the VRF name listed in the following format: tenant-name:vrf-name. This is the format you need to use in the show ip route command.
Stay safe,
Sergiu
RedNectar
Hi @valentik ,
My friend @Sergiu.Daniluk is absolutely on the right track, but he failed to mention that you don't need to log into each of the 70 leaf switches to achieve the output of show ip route vrf <VRF-NAME>
Instead, you can issue the same command from the APIC using the fabric <id> <command> construct.
So if your leaves had IDs of say 2101-2170, you could get ALL the routes with a single command issued form any APIC
fabric 2101-2170 show ip route vrf all
BUT be ready for a lot of output.  I issued the command on our lab with just two switches below - its over 900 lines long! And then you'd have to re-organise it into VRFs probably.  IF you wanted just EXTERNAL routes (learned from say OSPF) the result would be a lot smaller. So to show just OSPF learned routes, use
fabric 2101-2170 show ip route ospf vrf all
So TBH - I think you'd be better off trying to either write a python script or (as you suggested) learn a little Ansible to achieve your result.
I thought about using BASH - but it didn't work.  The following command (on the APIC) collects a list of the VRFs in the correct format:
apic1# vrfList=$(moquery -c fvCtx | grep ^dn | cut -c 31- | sed 's#/ctx-#:#')
apic1# echo $vrfList
mgmt:oob
common:SharedServices_VRF
infra:ave-ctrl
common:default
common:copy
infra:overlay-1
mgmt:inb
Tenant06:Production_VRF
Lab:Lab
<...snip...>
But my attempt to feed this into a fabric <id> <command> format failed
apic1# for v in $vrfList; do fabric 2201-2202 show ip route vrf $v; done
Invalid return character or leading space in header: APIC-Client
FYI - here's a trimmed version output of the fabric 2201-2202 show ip route vrf all on out lab
apic1# fabric 2201-2202 show ip route vrf all
 Node 2201 (Leaf2201)
IP Route Table for VRF "overlay-1"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%' in via output denotes VRF
0.0.0.0/32, ubest/mbest: 1/0
    *via 10.2.16.65, eth1/49.86, [115/12], 08:11:14, isis-isis_infra, isis-l1-ext
10.2.0.0/27, ubest/mbest: 1/0, attached, direct
    *via 10.2.0.30, vlan8, [0/0], 1d16h, direct
10.2.0.30/32, ubest/mbest: 1/0, attached
    *via 10.2.0.30, vlan8, [0/0], 1d16h, local, local
10.2.0.32/32, ubest/mbest: 2/0, attached, direct
    *via 10.2.0.32, lo1023, [0/0], 1d16h, local, local
    *via 10.2.0.32, lo1023, [0/0], 1d16h, direct
10.2.0.33/32, ubest/mbest: 1/0
    *via 10.2.16.65, eth1/49.86, [115/2], 1d16h, isis-isis_infra, isis-l1-int
10.2.0.34/32, ubest/mbest: 1/0
10.2.0.35/32, ubest/mbest: 1/0
10.2.0.64/32, ubest/mbest: 2/0, attached, direct
    *via 10.2.0.64, lo1, [0/0], 1d16h, local, local
    *via 10.2.0.64, lo1, [0/0], 1d16h, direct
10.2.0.65/32, ubest/mbest: 1/0
10.2.0.66/32, ubest/mbest: 1/0
10.2.0.67/32, ubest/mbest: 1/0
10.2.16.64/32, ubest/mbest: 2/0, attached, direct
    *via 10.2.16.64, lo0, [0/0], 1d16h, local, local
    *via 10.2.16.64, lo0, [0/0], 1d16h, direct
10.2.16.65/32, ubest/mbest: 1/0
10.2.16.66/32, ubest/mbest: 1/0
    *via 10.2.16.65, eth1/49.86, [115/3], 08:11:14, isis-isis_infra, isis-l1-int
10.2.184.65/32, ubest/mbest: 1/0
10.2.184.66/32, ubest/mbest: 1/0
10.2.184.67/32, ubest/mbest: 1/0
10.3.2.0/24, ubest/mbest: 1/0
    *via 10.2.16.65, eth1/49.86, [115/11], 1d16h, isis-isis_infra, isis-l1-ext
10.3.8.11/32, ubest/mbest: 1/0
    *via 10.2.16.65, eth1/49.86, [115/64], 1d16h, isis-isis_infra, isis-l1-ext
10.3.8.12/32, ubest/mbest: 1/0
10.3.9.2/32, ubest/mbest: 1/0
10.3.12.225/32, ubest/mbest: 1/0
10.3.12.226/32, ubest/mbest: 1/0
<snip aout 200 lines>
IP Route Table for VRF "Tenant07:Production_VRF"
10.200.0.5/32, ubest/mbest: 1/0, attached, direct, pervasive
    *via 10.2.0.65%overlay-1, [1/0], 16:56:38, static, rwVnid: vxlan-2523136
10.207.11.0/24, ubest/mbest: 1/0, attached, direct, pervasive
    *via 10.2.0.65%overlay-1, [1/0], 16:56:38, static, tag 4294967294
10.207.11.1/32, ubest/mbest: 1/0, attached, pervasive
    *via 10.207.11.1, vlan37, [0/0], 16:56:38, local, local
10.207.12.0/24, ubest/mbest: 1/0, attached, direct, pervasive
    *via 10.2.0.65%overlay-1, [1/0], 15:49:01, static, tag 4294967294
10.207.12.1/32, ubest/mbest: 1/0, attached, pervasive
    *via 10.207.12.1, vlan97, [0/0], 15:49:01, local, local
<snip about 200 lines >
 Node 2202 (Leaf2202)
    *via 10.2.0.1, vlan8, [1/0], 08:24:48, static
<snip about 400 lines>
RedNectar aka Chris Welsh.
Sergiu.Daniluk
I think the reason why I didn't put the "show ip route vrf X" in the context of 70 leafs is because the instances you will really check the routing table on all 70 leafs are close to none. 99% of the time you check the routing table on the Border Leafs (where the L3Out is configured), and, if the config is correct, the prefixes should propagate to the appropriate compute leafs via MP-BGP.
On the other hand, yes, you can check the routing table on multiple leafs at once if necessary (during tshoot for example) using the commands described so clear by Chris.
Cheers,
Sergiu
Sergiu.Daniluk
Cheers,
Sergiu
I made some research about interfaces :
the informations I need to collect (export) as Interfaces are in format :
L3OUT_COMMON_TO_MAN_L3/topology/pod-2/node-2003/eth1/1/vlan-212, 10.56.239.1, 255.255.255.0, common/VRF_ONE
L3OUT_COMMON_TO_MAN_L3/topology/pod-2/node-2003/eth1/1/vlan-212 : Tenant, L3Outs, Logical Node Profile, Logical Interface Profile, Routed Sub-Interface
10.56.239.1 : IP Address
255.255.255.0 : Netmask (calculated)
common/VRF_ONE : Tenant/VRF
How to export all informations from all tenants and VRF ?
Thanks in advance
Valentino
The informations present in Tenant-name -> VRF-name -> Operational -> Route table seems to be the right one.
I used moquery to recover all routes, but I have a little more than 300K
How to export in a text file moquery results ?
I made some search about some option to send results in a file without success ?
Do I need to use API REST ? Another tool ?
Valenitno Kusmic
