Single Node Nexus Dashboard
Rem Markov
Level 5
Level 5
Hey ! I'm kind of lost whatever is possible to create a single Node or 2 nodes cluster with Nexus Dashboard.
Also I'm running into so problem.
I have understood that when I set a management network when the initial setup appears will eventually tell me the url to go to. But the URL never appears , it justs let's me connect to rescue-user and when check the integrity of the cluster it just says clasterd is unhealthy.
Any suggestions?
Rem Markov
Level 5
Level 5
The problem was me , I didn't set vlans.
Rem Markov
Level 5
Level 5
