Cisco ACI: extend/stretch vlan without mso
Hi guys,
Can you extend/stretch vlan without MSO between two different Fabric? I will have the same Tenant, BD and VRF configurations on both the Fabrics.
Topology:
leaf<-trunk->N9k<-trunk->N9k<-trunk->leaf
Thanks.
Robert Burns
Yes, this is simply a Layer2 extension via EPG Static Path.  I'd be cautious with this since without MSO/NDO you don't have any ability to limit flooding behavior between the fabrics.  Something that MSO/NDO can protect your fabric's flood domain against.
Robert
Robert Burns
Robert
