SPINE does not upgrade on a Multipod deployment
IsaacGV
I have a multipod deployment but Im trying to upgrade a spine switch (N9K-9364C).
The upgrade do not start and the gui do not shows any fault. The status colum shows NOT SCHEDULE.
I tried many times.
Application Policy Infrastructure Controller
Version: 4.2(5k)
Sergiu.Daniluk
This might sound as a trivial question, but have you selected "upgrade start time" as "Now"?
If yes, can you verify what is in the Admin > Schedulers > Fabric > name_of_your_upgrade_group what time you have selected, if any.
Stay safe,
Sergiu
IsaacGV
Hi Sergiu
Yes, I selected "upgrade start time" as "Now.
I tried with another options like check and unckeck "Ignore compatibility" but it does not work.
