Static path binding for vpc option not coming in aci
niceinfotech
I have created four vpcs-ipg in the fabric policy but when trying to bind it to the static port
in EPG of the Application profile then the fourth option(which i need to add HXV-VPC-IPG)  is not coming.
Please help out since I am a newbie in configuring ACI. I am posting all the configuration below.
VLAN-POOLS
AAEP
DOMAINS
VPC-PROTECTION-GROUP
INTERFACE:VPC-POLICY-GROUP
INTERFACE:PROFILE
SWITCH:PROFILE
EPG: STATIC-PORT DEPLOYMENT (This is where i am facing the problem. I cannot select for the HXV-VPC-IPG) why is it not giving me this option ? Is there anything more that I need to do or maybe I have left out something?
HI @niceinfotech ,
Much better.  Your error message shows that that port 49 is the problem. Now most ACI Leaf Switches have 48 access ports - ports 49-54 are uplink ports.  However, you can convert uplink ports to downlink.
My suspicion is that port 49 on leaf 101 has NOT been converted to a downlink port
RedNectar aka Chris Welsh.
RedNectar
Hi @niceinfotech ,
Firstly, thanks so much for providing such a full set of screendumps. Without them, I wouldn't have caught this error.
I think before we go down any rabbit-holes, you need to fix this error.
[Later edit]
I should also mention that BEFORE you go trying to deploy a VPC on an EPG, it is a good idea to
  1. navigate to the relevant VLAN Pool, and click the Show Usage button to validate that the ports in the PVC show up (as I explained in this recent answer)
  2. navigate to the EPG >| [Operational] > [Configured Access Policies] to verify that the VPCIPG shows up there.
[/edit]
Thank you for your reply @RedNectar this is the error notification that I found in the Fault option. Can you please explain what is this and how do we solve it?
HI @niceinfotech ,
Thank you @RedNectar now it is solved I changed the port to downlink and now we can use as the epg port. Thanks alot you save our time.
