Subnet on EPG and/or BD for Co-existence of Network-centric and application-centric mode
clement_cheung
Hi experts
I have an ACI fabric currently designed based on network-centric mode and needs inter-VRF route leaking.  Therefore there is one-one mapping among subnet, EPG and BD, and the subnet is defined under EPG rather than the BD.  This design is aimed for ease of migration of endpoints from classical network to ACI.
I however foresee that after migration, we may need to 'rewire' some migrated endpoints, without changing IP addresses, to new EPG which acts as Application Component Group so special contracts can be applied for micro-segmentation.
How to do that ? Where should the subnets be placed EPG and/or BD ?
18 Replies 18
Clement,
The consumer leaf will have a pervasive route for the provider BD installed (nexthop = Spine IPv4 proxy) due to the route leaking. If the provider endpoint isn't learned on the consumer leaf, then it will simply punt the packet to spines with some specific values in the outer iVXLAN header. The sclass of the consumer EPG will be included and the VRF VNID of the provider will be marked too. Spines will do IPv4 lookup for the destination IP within the provider VRF (due to the VNID in the outer iVXLAN header) and handle the packet appropriately. Once the destination leaf (provider leaf) receives the packet, it will use the sclass in the outer iVXLAN header to determine the source EPG. The destination class is derived from the locally learned endpoint information. From there the destination leaf should be able to apply policy.
-JW
Thanks for the explanation!
exactly !!!
But if this is the case, why do I need the provider EPG necessarily having the subnet defined as its son ? why can't the subnet be defined under the bridge domain to which the provider EPG is associated to ? If everything is based on conversational learning, than it should work. You filter packets based on contracts on innter leafs when you can and already know the destination EPG, otherwise the work will be done on the egress leaf (using spine proxy).
