switching port error disable
sree2k141
Hi all,
 Please give the detail information why the port goes error disable.
regards,
Srikanth.G
Charles Hill
The link below discusses err-disabled ports.
http://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/69980-errdisable-recovery.html
Info below is from Cisco doc:
"There are various reasons for the interface to go into errdisable. The reason can be:
  • Duplex mismatch
  • Port channel misconfiguration
  • BPDU guard violation
  • UniDirectional Link Detection (UDLD) condition
  • Late-collision detection
  • Link-flap detection
  • Security violation
  • Port Aggregation Protocol (PAgP) flap
  • Layer 2 Tunneling Protocol (L2TP) guard
  • DHCP snooping rate-limit
  • Incorrect GBIC / Small Form-Factor Pluggable (SFP) module or cable
  • Address Resolution Protocol (ARP) inspection
  • Inline power
Troubleshoot
  • show interfaces status err-disabled—Shows which local ports are involved in the errdisabled state.
  • show etherchannel summary—Shows the current status of the EtherChannel.
  • show errdisable recovery—Shows the time period after which the interfaces are enabled for errdisable conditions.
  • show errdisable detect—Shows the reason for the errdisable status."
Hope this helps,
please rate helpful posts.
Thanks.
Hi Charles,
 I got valid information thanking you
