12-10-2025 05:18 AM
Hello Freinds
the ACI running slowly,APIC is 3.2 whereas N9K Version is n9000-15.2(6e)
How to open a Technical TAC Case regarding ACI , Pls note we don't havea Service contract with Cisco, as we bought the device from non-cisco partner , Pls Pls Advice
thanks
12-10-2025 05:33 AM
You need to upgrade APICs to the same or higher version than the switches. To be able to download the APIC firmware, you need a valid contract with Cisco through a Cisco channel partner.
The best thing to do is to discuss the situation with the available Cisco channel partners in your region/country, so that they provide you with an offer to include all ACI hardware - if possible - in a support contract. It might not be cheap, but it is cheaper than having your production ACI fabric go sideways right before payroll day.
12-16-2025 02:28 PM
APIC is running 3.2 ... ?
You should upgrade to 6.0 as soon as possible, please mind the upgrade path:
https://www.cisco.com/c/en/us/td/docs/Website/datacenter/apicmatrix/index.html#cur=3.2(4)&tar=6.0(9)
