Vlan Pool Dynamic - current usage
ChrisB.
Frequent Visitor
Frequent Visitor
hello,
does anyone knows how i could list the Vlan ID being used (mapped) for a dynamic Vlan pool.
this pool ( range of 200 vlan IDs ) has been created for VMM integration.
how can list with the CLI the ID used ( through the GUI Fabric > Access policies > Pools/Vlans/ MYVLAN_POOL >> show usage
thanks in advance
10 Replies 10
Robin9
Frequent Visitor
Frequent Visitor
You can try this cli on apic # show vlan-domain detail name  MYVLAN_POOL
ChrisB.
Frequent Visitor
Frequent Visitor
it gives me an empty output :
Legend:
vlanscope: L (Portlocal). Default is global
Robin9
Frequent Visitor
Frequent Visitor
after this line (vlanscope: L (Portlocal). Default is global) you will see the some out
I just checked in my lab form one of the apic i have static vlan pools there.
ChrisB.
Frequent Visitor
Frequent Visitor
empty output
Legend:
Robin9
Frequent Visitor
Frequent Visitor
okey if you just execute the cli #show vlan-domain details name <--- enter tab and see if you see all your available vlan pool here.
ChrisB.
Frequent Visitor
Frequent Visitor
here it lists the Physical domain. unefortunately doesn't list my virtual domain
show vmware domain name <NAME OF YOUR VMM DOMAIN> port-group
This shows you the vlans currently used as encaps in port-groups.
hello
thanks for your reply.
forget to say that i have a microsoft domain and i don't see the encap in the output :
here are my line headers :
 Name                            Type   Virt. Net. Adapters   Mgmt. Net. Adapters
Just to be sure: You used
show microsoft domain name <VMM DOMAIN NAME> port-group
then, right?
Unfortunately I don't have a Hyper-V environment connected to the fabric so I can't check that...
Hi Nik
yes i did try this command with the Microsoft instead of Vmare and i don't have the Vlan ID picked from my Dynamic VMM pool of IDs
