VMKernel Port Push from ACI EPG
Xdxb
I know I am thinking wrong. But still want to get it clear from my head.
Is it possible to push the VMKernel port from ACI egp? or only way to configure manually on dvs / standard vSwitch?
Alexander09
If you do VMWare integration, this means you will push the VDS towards vsphere and this will configure uplink portgroups for the distributed switch.
If you have vmm integration and you add the vmm domain under the EPG a port group is created under the distributed switch, under the EPG no vmkernel ports are created, uplink port groups these are created when configuring vmm integration.
cheer-i-o
Alexander
Alexander Deca
Robert Burns
Can you create/push VMK Interfaces from ACI for use on vCenter - No.
Can you create the EPG/PortGroup that a VMK can be assigned to on vCenter - Yes.
ACI doesn't create endpoint interfaces, only Port Groups (which are a representation of an EPG).
Robert
