06-14-2019 11:22 PM
I get response for l1physIf and the speed attribute has "inherit" , what value should be considered.
unknown | 0 | Unspecified | Speed is unknown |
100M | 1 | 100 Mbps | Speed is 100 Mbps |
1G | 2 | 1 Gbps | Speed is 1 Gbps |
10G | 3 | 10 Gbps | Speed is 10 Gbps |
25G | 4 | 25 Gbps | Speed is 25 Gbps |
40G | 5 | 40 Gbps | Speed is 40 Gbps |
100G | 6 | 100 Gbps | Speed is 100 Gbps |
inherit | 7 | inherit | Speed is Inherited |
06-15-2019 12:06 AM
i think it means .. speed inherited from the port profile.
02-18-2020 05:19 AM
Hello, I cannot seem to find a way from the link to get to the port profile being applied to the interface in CISCO APIC.
How do you do it? Isn't there maybe another way like, for example, to get the effective speed value being applied?
