Will Implementing vPC Pairing Between Leaf Switches Cause L2 Downtime?
Andi Bintang
Hello everyone,
I'm new to this community and super excited to join the discussions here. I have a big curiosity about something I'm working on right now.
I've just added a few new leaf switches to my ACI fabric and I'm planning to set up vPC pairing between them. My data center is quite complex, and I'm a bit worried about the possible impact on the network.
So, here's my big question. will implementing vPC pairing between leaf switches cause any Layer 2 (L2) downtime in a real production environment? or maybe what steps should I take to ensure everything goes smoothly without disrupting the existing network?
Thanks a lot for your help and advice!
AshSe
Hello Andi,
Below are the precautionary steps before configuring vPC in Cisco ACI using the APIC:
  1. Pre-Implementation Planning
  • Review Documentation: Ensure you understand the Cisco ACI vPC configuration process by reviewing the official documentation.
  • Network Assessment: Identify the devices and connections that will be affected by the vPC implementation.
  • Backup Configuration: Ensure you have a backup of the current configuration and a rollback plan.
  1. Preparation
  • Firmware Compatibility: Verify that the firmware versions on the leaf switches are compatible with the vPC feature.
  • Configuration Consistency: Ensure that the configurations on the leaf switches are consistent and that there are no conflicting settings.
I hope you already know how to configure vPC, it’s quite simple and straight forward. Feel free if you still have doubt.
Happy configuration!!
AshSe
Please rate this post if it was helpful; your feedback is appreciated!
AshSe
Hello Andi,
  1. Preparation
AshSe
