05-02-2017 06:03 PM - edited 03-01-2019 05:13 AM
Hoping this is something easily solved. I'm new to ansible, ACI, and the Cobra SDK. I'm seeing this error when I try to run an ansible playbook that uses Jason Edelman's aci-ansible library. It's not finding the Cobra SDK, even though it appears to be installed. The specific error when I run the playbook is:
fatal: [10.10.10.10]: FAILED! => {"changed": false, "error": "No module named cobra.mit.access", "failed": true, "msg": "Ensure you have the ACI Cobra SDK installed"}
And here are the steps I've taken to install the ansible library and SDK, most of which comes directly from the instructions posted on the ACI controller.
git clone https://github.com/jedelman8/aci-ansible.git ~/ansible/aci-ansible
mkdir ~/cobra_sdk_2.2_1o
cd ~/cobra_sdk_2.2_1o
sudo easy_install virtualenv
cd ~
virtualenv cobra_sdk_2.2_1o
source cobra_sdk_2.2_1o/bin/activate
easy_install -Z acicobra-2.2_1o-py2.7.egg
easy_install -Z acimodel-2.2_1o-py2.7.egg
Once this is done, it appears to be there and working.
(cobra_sdk_2.2_1o) sdfsd@sfsdf12:~/cobra_sdk_2.2_1o$ pip freeze
acicobra===2.2-1o
acimodel===2.2-1o
appdirs==1.4.3
packaging==16.8
pyparsing==2.2.0
requests==2.13.0
six==1.10.0
I'm also able to import from python.
(cobra_sdk_2.2_1o) sdfd@sdfd12:~/cobra_sdk_2.2_1o$ python
Python 2.7.12 (default, Nov 19 2016, 06:48:10)
[GCC 5.4.0 20160609] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from cobra.mit.access import MoDirectory
And here is my playbook:
- hosts: "{{ host_list }}"
gather_facts: no
connection: local
tasks:
- name: define user
set_fact:
user: bart
- name: define pass
set_fact:
pass: simpson
- name: build a test bridge domain
aci_bridge_domain: name=1212_DELETEME context=aaa tenant=b state=present host={{ inventory_hostname }} username={{ user }} password={{ pass }}
- name: remove a test bridge domain
aci_bridge_domain: name=1212_DELETEME context=aaa tenant=b state=absent host={{ inventory_hostname }} username={{ user }} password={{ pass }}
But whenever I run it, it fails with the following error (same as listed above). Any ideas?
fatal: [10.0.49.34]: FAILED! => {"changed": false, "error": "No module named cobra.mit.access", "failed": true, "msg": "Ensure you have the ACI Cobra SDK installed"}
Thanks in advance for any insight!
06-01-2017 07:14 AM
Have you tried using, ansible_python_interpreter, to force Ansible to use Python that is within your virtualenv? I believe that by default Ansible will try to use /usr/bin/python
Here is an example that I use on my system
07-29-2021 12:03 PM
Hi @black
We opened a forum in French with an ACI expert & VIP of the community Francesco Molino who answered your question. Please validate his reply as "accepted solution" here or visit our forum !
Hi @black
I see your playbook refers to a module called aci_bridge_domain which doesn't exist in the code you are using.
The correct module would be: aci_bd.
Also, you can share the contents of your ansible.cfg file or your host file which should refer the python program to use:
ansible_python_interpreter=/usr/bin/python3
Now this library is 4 years old and I would advise you to use the ansible cisco.aci collection (https://galaxy.ansible.com/cisco/aci)
You will need to use aci_bd and aci_bd_subnet. On the web page of the cisco.aci collection on ansible, you will find the different parameters to use as well as examples.
For info, here is an example below
- name: Create Bridge Domain aci_bd: host: '{{ ansible_host }}' username: '{{ username }}' private_key: '{{ private_key }}' certificate_name: '{{ certificate_name }}' validate_certs: no tenant: '{{ item.TENANT }}' bd: '{{ item.BD }}' vrf: '{{ item.VRF_FULL }}' enable_multicast: 'yes' enable_routing: 'yes' l2_unknown_unicast: 'proxy' l3_unknown_multicast: 'flood' multi_dest: 'bd-flood' arp_flooding: 'yes' state: present tags: l3 loop: '{{ l3_list }}' - name: Create Bridge Domain Subnet aci_bd_subnet: host: "{{ ansible_host }}" username: '{{ username }}' private_key: '{{ private_key }}' certificate_name: '{{ certificate_name }}' validate_certs: no tenant: '{{ item.TENANT }}' bd: '{{ item.BD }}' gateway: "{{ item.ANYCAST_GATEWAY }}" mask: "{{ (item.BD_SUBNET).split('/')[1] | int }}" scope: public state: present tags: l3 loop: '{{ l3 }}'
In my example, there is a loop which calls a variable l3 because I am using an excel file with several subnets to create but if you want a single bridge-domain, you can adapt it as follows:
- name: Create Bridge Domain aci_bd: host: '{{ ansible_host }}' username: '{{ username }}' private_key: '{{ private_key }}' certificate_name: '{{ certificate_name }}' validate_certs: no tenant: 'TEST_TENANT' bd: 'TEST_BD' vrf: 'TEST_VRF' enable_multicast: 'yes' enable_routing: 'yes' l2_unknown_unicast: 'proxy' l3_unknown_multicast: 'flood' multi_dest: 'bd-flood' arp_flooding: 'yes' state: present - name: Create Bridge Domain Subnet aci_bd_subnet: host: "{{ ansible_host }}" username: '{{ username }}' private_key: '{{ private_key }}' certificate_name: '{{ certificate_name }}' validate_certs: no tenant: 'TEST_TENANT' bd: 'TEST_BD' gateway: "10.10.10.1" mask: "24" scope: public state: present
