Cisco ACI FI switch connections
amitkulshrestha
Hi All ,
 I am working on new AIC project. In this implementation, there is no license for VMware integration (Came with VMware standard license) , my solution architect confirm me that no integration required , so plz guide me how will i connect & configure  leaf switch to FI switch. Document related to same are unable, although vmm integration document and guides are available.
Amit
Sergiu.Daniluk
HI @amitkulshrestha
If no VMM integration is being done, then you will have a Phy Domain towards UCS, and you will manually configure the vlans association to EPGs. For redundancy, you will configure one vPC towards FI-A, and one vPC towards FI-B. The vlans associated to PhyDomain needs to be configured on UCSM.
Stay safe,
Sergiu
Sergiu.Daniluk
HI @amitkulshrestha
Stay safe,
Sergiu
Thanks .
