Elasticsearch dashboard/use case for aci
Thorgal
Hello
Does anyone logg their aci enviorment to elk (or splunk)? Can you get any intresting data from the logs or perheps you need to build with the api insted (for example https://github.com/CiscoSE/aci-dashboard) then perhaps using logs is not enough.
0 Replies 0
