How do we check if ACI LEAF interface are configured with QOS ?
Hi Experts ,
Do we configure QOS in ACL LEAF switches ?
How do we check if QOS is configured on the leaf switch ?
How do we check the running config for interface APIC GUI ?
Ezzedine
hi @Network_Sarovani
using this command will show you the details of the QoS on an interface , if you have edited the general QoS you should see the same impact on all the interfaces.
spine-191# show queuing interface ethernet 1/31 detail
                             Queuing stats for ethernet 1/31
                             Qos Class level3
Rx Admit Pkts :  0                      Tx Admit Pkts :  261347238
Rx Admit Bytes:  0                      Tx Admit Bytes:  74156823366
Rx Drop Pkts  :  0                      Tx Drop Pkts  :  0
Rx Drop Bytes :  0                      Tx Drop Bytes :  0
                             Qos Class level2
Rx Admit Pkts :  0                      Tx Admit Pkts :  0
Rx Admit Bytes:  0                      Tx Admit Bytes:  0
                             Qos Class level1
                             Qos Class policy-plane
Rx Admit Pkts :  287414769              Tx Admit Pkts :  867382198
Rx Admit Bytes:  53628002158            Tx Admit Bytes:  534952594475
                             Qos Class control-plane
Rx Admit Pkts :  1226839944             Tx Admit Pkts :  3922150
Rx Admit Bytes:  1378311605748          Tx Admit Bytes:  411328965
                             Qos Class span
                             Qos Class level6
                             Qos Class level5
                             Qos Class level4
in ACI you can apply a Custom Policy on one EPG so this policy will be applied on all the the attached interfaces:
Procedure
Step 1
Log in to your Cisco APIC GUI.
Step 2
From the horizontal navigation bar, select Tenants > <tenant-name>.
Step 3
In the left-hand navigation pane, expand <tenant-name> > Policies > Protocol > Custom QoS.
Step 4
Right click the Custom QoS and choose Create Custom QoS Policy.
Step 5
Provide the name and an optional description of the custom QoS policy information.
Step 6
Create a DSCP mapping for one or more QoS priority levels.
The DSCP mapping allows you to map ingress DSCP values to a QoS priority level as well as the egress DSCP and CoS value for traffic that leaves the ACI fabric. For each mapping, you can specify the following fields:
Name Description
PriorityThe QoS priority level to which the DSCP values will be mapped.
DSCP Range FromThe start of the DSCP range.
DSCP Range ToThe end of the DSCP range.
DSCP TargetThe DSCP value for egressing traffic.
Target CosThe CoS value for the egressing traffic.
Step 7
Create a CoS mapping for one or more QoS priority levels.
The CoS mapping allows you to map ingress CoS values to a QoS priority level as well as the egress DSCP and CoS value for traffic that leaves the ACI fabric. For each mapping, you can specify the following fields:
Name Description
Dot1P Range FromThe start of the CoS range.
Dot1P Range ToThe end of the CoS range.
Step 8
Click Submit to save the changes.
Step 9
Attach the custom QoS policy you created to an EPG.
  1. Navigate to Tenants > <tenant-name> > Application Profiles > <application-profile-name> > Application EPGs > <application-epg-name>.
  2. In the main window pane, select Policy > Generalthe custom QoS policy you created.
  3. In the main window pane, select the custom QoS policy you created from the Custom QoS drop down menu.
Configuring QoS Directly on L3Out Using GUI
This section describes how to configure QoS directly on an L3Out. This is the preferred way of configuring L3Out QoS starting with Cisco APIC Release 4.0(1).
Procedure
Step 1
From the main menu bar, select Tenants > <tenant-name> .
Step 2
In the left-hand navigation pane, expand Tenant <tenant-name> > Networking > L3Outs > <routed-network-name> > Logical Node Profiles > <node-profile-name> > Logical Interface Profiles > <interface-profile-name>.
You may need to create new network, node profile, and interface profile if none exists.
Step 3
In the main window pane, configure custom QoS for your L3Out.
You can choose to configure a standard QoS level priority using the QoS Priority drop-down list. Alternatively, you can set an existing or create a new custom QoS policy from the Custom QoS Policy dropdown.
for more information please visit : Cisco APIC and QoS
hope that could help you.
best regards
Ezzedine
Ezzedine
@Network_Sarovani
in addition you can use this CLI commands:
Fabric QoS Debugging - CoPP CLI
<show copp policy>
<show system inernal aclqos brcm coppp entries unit 0> - CoPP statistics (red = dropped, green = allowed)
<show system internal qos classes> - shows QoS classes configured
<show system internal qos vlan all> - shows QoS classes/policices configured per vlan
<show system internal qos ppf [pinst|nodes]> - shows ppf details
<show system internal aclqos qos classes> - shows QoS classes configured in hardware
<show system internal aclqos qos vlan (vlanID)> - shows the QoS DSCP/dot1p policy configured for a vlan in HW
<show system internal aclqos qos policy summary> - shows QoS DSCP/dot1p policy summary
<show system internal aclqos qos policy detail> - shows QoS DSCP/dot1p policy in detail
<show system internal aclqos brcm tcam entries unit 0 group [efp-bpdu|efp-ctrl-pol|efp-mark|ifp-ctrl|ifp-dscp|ifp-elmc-vleaf|ifp-span-port-vlan|ifp-span-port-vlan-egress|ifp-span-vlan-egress|ifp-vni-udf|vfp-vni]> - shows T2 TCAM entries for specified group
<show platform internal counters port (#)> - shows QoS counters on each port
<show platform internal counters port internal (#)> - shows QoS counters on each port (internal)
<show platform internal counters class (#)> - shows QoS counters for each class for all ports
Can we configure QOS on ACI for particular application ? say the application name or url is example.com (10.10.10.1)
