How to maintain APIC Session between 2 Cobra python scripts
Mathieu M
Hello all,
Using the Cobra SDK, how is it possible to re-use an already established APIC Session ?
The main use case is :
1/ First using a script to create a session, that would perform the login (so that I ask the password, once)
2/ Run several and independant python scripts to perform different tasks reusing the previously created session (without storing the password in a script or in a environment variable).
Using plain REST API, it is possible to re-use the session cookie.
How is it possible with the Cobra SDK ?
Thank you in advance for any hint,
Sincerely yours, Mathieu.
0 Replies 0
