11-27-2018 07:07 AM - edited 03-01-2019 05:42 AM
I am considering using the vzAny EPG to simplify some configurations and possibility save a little TCAM.
The goal is to use MSO for all EPG and contract definitions, but I can't find how to use vzAny from the MSO.
Running APIC 4.0 with MSO 2.0.
Streched bridge domains and EPGs over two sites/fabrics.
Thanks for your help !
Eric
Solved! Go to Solution.
10-07-2019 02:37 AM - edited 12-07-2020 08:10 AM
Hi @emorgan,
As of today, you can configure vzAny contracts only on the APIC.
Configuration support for vzAny contracts on MSO so those can be pushed to all sites is coming (tentatively Q1CY20).
Stay tuned to the release notes for when this feature becomes available in future versions
Cisco Application Policy Infrastructure Controller (APIC)
UPDATE
You can configure vzAny from MSO starting MSO 2.2(4) / APIC 4.2(4)
Software Download
ACI Multi-Site Software
Cheers.
PS: You can also evaluate the use of Preferred groups to avoid having to use contracts between EPGs in Multi-site.
Preferred groups was introduced in 2.0(2) for MSO and 4.0(2) for APIC
Cisco ACI Multi-Site Configuration Guide, Release 2.1(x)
Chapter: Schema Management
Hi @emorgan,
UPDATE
Software Download
Cheers.
02-13-2020 01:25 AM
Is there an update to availability of this feature on MSO?
02-13-2020 02:49 AM - edited 02-13-2020 08:27 AM
vzAny in ACI Multi-Site is planned for APIC version 4.2(4) and MSO version 2.2(4) to be released in Q1CY20.
Note this information is subject to change without previous notice.
02-13-2020 03:18 AM
Thanks. What about VRF options such as policy enforcement - enabling or disabling?
02-13-2020 08:32 AM - edited 02-13-2020 08:34 AM
Hi @rkiokoinfra
There are no plans for the VRF option Policy Control Enforcement Preference (aka “VRF unenforced”) with Multi-Site.
The feature to be used instead is Preferred Groups or vzAny (once available) in Multi-Site Orchestrator.
