access dashboard from external
dstoeckm@cisco.com
When I start the dashboard with "./smm dashboard " I can reach the service only local.
opening Service Mesh Manager at http://127.0.0.1:50500
how do I export that to external web browser on a diff workload?
Alexander Stevenson
Hello dstoeckm@cisco.com,
Please see the section Exposing the Dashboard, from the SMM/Calisti docs:
https://smm-docs.eticloud.io/docs/dashboard/configuration/exposing/
hanjpark
It's not guaranteed way from document ,
but if you want to connect calisti via server IP from your laptop (not 127.0.0.1 from master node console) you can use Server Iptable forwarding method.
( It's not nodeport expose. it's server base ip forwarding. so it works only master server ip)
sysctl -w net.ipv4.ip_forward=1
iptables -t nat -A PREROUTING -i ens160 -p tcp --dport 30080 -j DNAT --to-destination 127.0.0.1:50500
ens160 is user server nic interface. 30080 is your choice for open port.
now you can connect http://serverip:30080
