license issue - Internal system error
eminchen
When launching dashboard I am getting this message:
You are over the resource limits that your license allows.
To access the dashboard, try to lower your resource usage or upgrade your license.
When checking details I see this error:
GraphQL internal system error
1.internal system error
What should I check? I am running version 1.9.1
eminchen
tiswanso
The pertinent info here is the graphql error.  The license check error is thrown because the access to the backend failed (graphql error).  Are there any obvious problems with the SMM related pods (`kubectl get pods -n smm-system`)?
