Calisti install issue
mathumma
HI Calisti team,
  I see the attached error during stage "registry-access/wait/readiness > waiting"
" error during operator reconcile: timed out waiting for the condition"
Please help me on fixing the issue.
7 Replies 7
yawming
Where you install SMM(Mac,Windows or Linux) ? What kind of cluster you have ? Single node of multi ?
What is the resource you have ?  CPU, Memory , storage ?
Try "kubectl get pods -A" to check what pods are having issue ?
Then describe those pods
Thanks for responding.
> I am having the stack on EKS. I am trying to access the cluster from remote machine.
>  I tried installation from Windows(WSL2) and also from MAC but same result.
> Its a single node EKS cluster.
> The node is t3.xlarge on aws. 4 vCPUS, 16GB RAM, 50GB storage.
> Do you want me to find pods of any particular namespace ??
Thanks.
hliu4
The cluster needs to have at least 12 vCPUs in total to continue. Could you try it on a larger cluster?
oh this I was not aware of. I will give this a try with 12 vCpus.
Selina
Here's a useful site - check out Prerequisites:  https://smm-docs.eticloud.io/docs/quickstart/
This will most likely change to calisti.app at some point, but should redirect for a while.
mathumma
Hi there,
Thanks for helping me to install Calisti so far. I was able to continue with install after increasing to 12+vcpus.
I see the issue in accessing dashboard because of healthcheck. (Attached screenshot)
Please help me if anything need to be done.
mathumma
Attached output as verbose.
