11501 SLB 2 webserver configuration problems,. ping test OK, but not work
satagraha
connecting 2 web servers,but it is not work.
ping test is good,
on client(any computer), http://193.193.10.50/ is not opened
e1 is to web sever1, e2 is to web server2
e9 is gigabit , to 6509 gigabit module(4/13)
interface 4/13 on 6509 is dot1q trunk
so confused, why doesn't work...?
CSS11501#
CSS11501#
CSS11501# sh run
!Generated on 04/20/2006 20:22:31
!Active version: sg0810002
configure
!*************************** GLOBAL ***************************
ip route 0.0.0.0 0.x.x.x.193.10.254 1
!************************* INTERFACE *************************
interface e1
bridge vlan 20
description " TO EKPWEB1 "
interface e2
bridge vlan 20
description " TO EKPWEB2 "
interface e9
description " TO BackBone6509_4/13"
!************************** CIRCUIT **************************
circuit VLAN1
ip address 193.x.x.x.255.255.0
circuit VLAN20
ip address 10.10.10.1 255.255.255.0
!************************** SERVICE **************************
service server1
ip address 10.10.10.2
active
service server2
ip address 10.10.10.3
active
!*************************** OWNER ***************************
owner komsco
content roundrobin
vip address 193.193.10.50
url "/*"
add service server1
add service server2
protocol tcp
port 80
active
CSS11501#
CSS11501# ping 193.193.10.254
Pinging 193.193.10.254 1 time(s)...
Working(-) 0/0 1/1
100% Success.
CSS11501# ping 193.193.9.2
Pinging 193.193.9.2 1 time(s)...
Working(-) 0/0 1/1
100% Success.
CSS11501# ping 193.193.30.2
Pinging 193.193.30.2 1 time(s)...
Working(-) 0/0 1/1
100% Success.
CSS11501# ping 10.10.10.2
Pinging 10.10.10.2 1 time(s)...
Working(-) 0/0 1/1
100% Success.
CSS11501# ping 10.10.10.3
Pinging 10.10.10.3 1 time(s)...
Working(-) 0/0 1/1
100% Success.
CSS11501#
Gilles Dufour
what's the default gateway configured on your servers ?
Try to configure this
group natclient
vip address 10.10.10.100
add destination service server1
add destination service server2
active
If it works after configure the above group, the problem is on the server.
Also, you did not configure the interface e9 as a trunk on the css.
Just so you know.
Gilles.
I tried 2nd solution ,but not working ,
interface e9
trunk
I did this, not connect to 6509switch by ping test..
It's another problem...
when you configure a trunk, you need to also specify the vlans and the default vlan
ie:
interface e9
vlan 1
default
But since you can ping the next-hop I do not think this is related to the interface, I just wanted to inform you that your interface was not setup for trunking.
Gilles.
