02-10-2011 02:29 PM
First of all by “L3VPNoMGRE” I mean “Dynamic Layer-3 VPNs (L3VPNs) (RFC 2547 based) with Multipoint GRE (mGRE) Tunnel Support”
I have a 2951 router with SM-SRE-900 module running WAAS, i`m running ip inspection on my LAN interface because L3VPNoMGRE does not have a dedicated WAN interface for the VRF. I found this tread https://supportforums.cisco.com/thread/20497063945 Router Issue between WAAS Module and IOS Firewall that had almost the same issue but that solution is not working for me because of the L3VPNoMGRE.
Now I`m wondering if anybody has the same problem or know of any workaround
Here is a summary of my configuration:
ip vrf BLUE rd 10:10
ip inspect name INSPECT_VRF-BLUE tcp
ip inspect name INSPECT_VRF-BLUE udp
ip inspect name INSPECT_VRF-BLUE cifs
ip wccp check services all
ip wccp vrf BLUE 61 redirect-list ACL-WAAS-EXCL-REDIRECT password xxx
ip wccp vrf BLUE 62 redirect-list ACL-WAAS-EXCL-REDIRECT password xxx
interface Loopback1
ip address 192.168.255.4 255.255.255.255
interface GigabitEthernet0/0 (WAN interface)
ip address 192.168.0.30 255.255.255.252
interface SM1/0
ip vrf forwarding BLUE
ip address 10.0.50.49 255.255.255.248
ip wccp redirect exclude in
service-module fail-open
service-module ip address 10.0.50.54 255.255.255.248
service-module ip default-gateway 182.23.50.49
interface GigabitEthernet2/0.1401
encapsulation dot1Q 1401
ip address 10.0.22.33 255.255.255.224
ip access-group IN-LAN in
ip access-group OUT-WAN out
ip wccp vrf BLUE 61 redirect in
ip wccp vrf BLUE 62 redirect out
ip inspect INSPECT_VRF-BLUE in
ip inspect INSPECT_VRF-BLUE out
l3vpn encapsulation ip ENCAP-VPNv4
transport ipv4 source Loopback1
Thanks for any tips and help.
02-21-2011 03:51 AM
I fear that WCCP and ZBFW integration is rather version specific. Which version are you running?
Peter
02-22-2011 10:17 AM
02-22-2011 11:57 PM
Hello Kristian,
I think I have seen the problem: with more recent versions of IOS (like the one you are using) you do not need to put the WAAS in the 'internal' zone, but in a seperate waas zone.
For an example with WAAS see the ZBFW documentation, in summary you need to have something like:
ip wccp 61
ip wccp 62 ip inspect waas enable ! on by defaultip wccp notifyzone security zone-inside zone security zone-outside
zone security zone-waas
zone—pair security inside—outside source zone-inside destination zone-outside
service—policy type inspect ...
zone—pair security outside—inside source zone-outside destination zone-inside
interface GigabitEthernet0/0 description Trusted interface ip wccp 61 redirect in zone—member security zone-inside ...interface GigabitEthernet0/1 description Untrusted interface ip wccp 62 redirect in zone—member security zone-outside ... ip wccp redirect exclude in zone—member security zone-waas ...
Could you try this?
Best regards, PeterDiscover and save your favorite ideas. Come back to expert answers, step-by-step guides, recent topics, and more.
